I read on thingaverse about using Aqua Net hair spray. Man, it works excellent. I just cover my glass plate with blue masking tape and take it outside and give that plate a spray with Aqua Net. The abs sticks really well. Hope this helps!
cheers,
tim
Aqua Net
- michaellatif
Re: Aqua Net
That's interesting! I will have to try that. Does this work for PLA also? How heavy of a coat do you put on? Does it leave a residue on the printed object? Can it be cleaned off?
Mike Latif
H-1 #3
H-1 #3
timothysvec
Re: Aqua Net
I'm only using abs so far.
tim
tim
Re: Aqua Net
Hair spray in general, or is there something special in that one?
Hmm, http://en.wikipedia.org/wiki/Hair_spray is interesting. Sounds like modern hair spray formulas actually contain spray-on acrylic or other plastics, which would explain why it would works for us.
Re: Aqua Net
Are you hearing the plate out will the abs stick cold with aqua net?
timothysvec
Re: Aqua Net
I'm heating to 180 F.
Re: Aqua Net
Suave from a pump bottle also works.Eric wrote:Hair spray in general, or is there something special in that one?
Re: Aqua Net
How easy do the printed parts come off when the bed is hot/cold?
timothysvec
Re: Aqua Net
No problem. I turn off the hot bed.... Let everything cool down... Them pry'm off with mt pocket knife. They just pop off about the same as with no hair spray. That stuff has been working really well for me.
