Aqua Net
timothysvec
Aqua Net
Post by timothysvec »
I read on thingaverse about using Aqua Net hair spray. Man, it works excellent. I just cover my glass plate with blue masking tape and take it outside and give that plate a spray with Aqua Net. The abs sticks really well. Hope this helps!
cheers,
tim
michaellatif
Re: Aqua Net
Post by michaellatif »
That's interesting! I will have to try that. Does this work for PLA also? How heavy of a coat do you put on? Does it leave a residue on the printed object? Can it be cleaned off?
Mike Latif
H-1 #3
timothysvec
Re: Aqua Net
I'm only using abs so far.
tim
Eric
Re: Aqua Net
Post by Eric »
Hair spray in general, or is there something special in that one?
Hmm, http://en.wikipedia.org/wiki/Hair_spray is interesting. Sounds like modern hair spray formulas actually contain spray-on acrylic or other plastics, which would explain why it would works for us.
xojins
Re: Aqua Net
Post by xojins »
Are you hearing the plate out will the abs stick cold with aqua net?
timothysvec
Re: Aqua Net
I'm heating to 180 F.
flink
Re: Aqua Net
Post by flink »
Eric wrote:Hair spray in general, or is there something special in that one?
Suave from a pump bottle also works.
xojins
Re: Aqua Net
Post by xojins »
How easy do the printed parts come off when the bed is hot/cold?
timothysvec
Re: Aqua Net
No problem. I turn off the hot bed.... Let everything cool down... Them pry'm off with mt pocket knife. They just pop off about the same as with no hair spray. That stuff has been working really well for me.
