In an earlier post you said you were planning on boring to a 60 degree angle as well drilling. Did you abandon that plan and just leave whatever countersink angle the drill bit causes?mhackney wrote:Yes, I am talking about the .40mm bore's length. There are photos I posted this weekend showing that the E3D bore is 2mm long - much longer than other nozzles. I simply drilled the 2mm hole that leads up to the .40mm bore a bit deeper with pin vise and 2mm drill bit. I'll try to draw something tomorrow.
E3D V4 All metal hotend
ceramichammer
- Plasticator
Re: E3D V4 All metal hotend
Yes, I didn't have any 60° bits and was too lazy to grind one. And frankly, after seeing the J-Head with the same angle, I put less emphasis on that dimension. The shorter nozzle bore is certainly performing much differently and much better so far. But, I will not be convinced until I have at least a solid week and 100s of prints on it.
I think the wall of that heat break is only 0.4mm thick. Look at it wrong and you'd risk snapping it.bvandiepenbos wrote:so don't use your big pipe wrench
ceramichammer
- Plasticator
I'm afraid I may have to grind one in order get the angle required for the 3.175 mm bore.mhackney wrote:Yes, I didn't have any 60° bits and was too lazy to grind one. And frankly, after seeing the J-Head with the same angle, I put less emphasis on that dimension. The shorter nozzle bore is certainly performing much differently and much better so far. But, I will not be convinced until I have at least a solid week and 100s of prints on it.
And then there's the bowden tube!!!
I just checked it. I would have never thought this. Check the video highlights!!!
The first is a SeeMeCNC-supplied Bowden, the second is one I got with an E3D purchase.
https://www.youtube.com/watch?v=Xbfa1u76fKY
http://dropc.am/p/KhiI1a
ceramichammer
- Plasticator
JohnStack wrote:And then there's the bowden tube!!!
You've summed up my sentiments.
What's the measured filament diameter in that video.
bvandiepenbos wrote:to get most thermal transfer to nozzle why not screw the nozzle into heater block FIRST until flat seats against block, then thread heat break in from other side until it bottoms against nozzle, then lastly screw heat break into the cooling fin body?? I have not done this yet, but am planning on assembling my E3D that way.
why leave the gap?
am I missing something here?
I wonder if the heater block is brought up to 300 deg C with the nozzle screwed all the way in, then the cold heat break already attached to the cold heat sink (might even put in freezer) is screwed in to the heater block quickly, you wouldn't have to do more than firmly finger tight with the heat sink (same tightness as E3d's instructions), because the heat break will expand as it comes up to the same temp as the heater block and nozzle and make the connection with the nozzle tighter.
The ID is 1.75 (and confirmed by E3D Support) and the walls are, I believe 1mm or 1.1. They're thicker than the SeeMeCNC's walls.Polygonhell wrote:What's the measured filament diameter in that video.
Personally, I think this is too tight. The Ezstruder flattens the filament out a bit.
Last night, my filament was measuring reliably 1.74 - 1.76 and today, it's 1.75 - 1.76. When it passes through the extruder and gets flattened, it goes to 1.68 - 1.72 and 1.77 - 1.79 if that makes sense.
I know I can't use theirs. Thank god I have just enough left.
BTW, just a quick stat about the hobbled gear, measuring in the belly of the cut:
New: 11.64 - 11.67
After 20 hours use: 11.44 to 11.56
After 250+ hrs use: 10.84 - 11.10
These things hold up pretty well!
I'll note that I also bought eight steppers from Ultimachine - but they're the same model # as SeeMeCNC's.
I'm at a loss. I'm back to the OEM Hot end this AM. I've got just enough SeeMeCNC bowden tube to print in the center of the bed!
That's odd, all of the E3D PTCs I've received are the black plastic ones that are bored so the PTFE Bowden tube can completely pass through them. This is needed on the hot end side so the PTFE "plugs in" to the top of the cold end. In the extruder side, I've modified my ezStruders so the Bowden tube goes right up to the hobbed gear.
It looks like the new brass PTC you got from E3D does not allow the Bowden to pass through all the way?
It is you say and no, I'm not going to mod my Ezstruder!!!! LOLmhackney wrote:That's odd, all of the E3D PTCs I've received are the black plastic ones that are bored so the PTFE Bowden tube can completely pass through them. This is needed on the hot end side so the PTFE "plugs in" to the top of the cold end. In the extruder side, I've modified my ezStruders so the Bowden tube goes right up to the hobbed gear.
I don't think I implied otherwise - except if you look at my cam, I had a doh moment and went ahead and attached the brass PTC to the other end of the OEM bowden - and now I'm out of all of it. Dammit!
- bvandiepenbos
Sounds like a excellence idea.Broose wrote:bvandiepenbos wrote:to get most thermal transfer to nozzle why not screw the nozzle into heater block FIRST until flat seats against block, then thread heat break in from other side until it bottoms against nozzle, then lastly screw heat break into the cooling fin body?? I have not done this yet, but am planning on assembling my E3D that way.
why leave the gap?
thanks, I am going to give that a shot.
http://www.Filastruder.com also sells them in the United States.aerouta wrote:Where did you folks order this hotend? here.. http://e3d-online.com/
McSlappy
Wow, so is that a new PTC from e3d? Like Mhackney said, this isn't the same PTC I got with my kit - mine are big black plastic ones...JohnStack wrote:And then there's the bowden tube!!!
No, E3D uses only black plastic fittings. He has installed a different fitting. Considering the E3D PTFE walls are slightly thicker, I am not surprised that this is causing binding.McSlappy wrote:Wow, so is that a new PTC from e3d? Like Mhackney said, this isn't the same PTC I got with my kit - mine are big black plastic ones...JohnStack wrote:And then there's the bowden tube!!!
This is incorrect, as I was CC'ed on the email John is referencing. The ID of E3D PTFE tube is 2.0mm, confirmed by both Sanjay and myself.JohnStack wrote:The ID is 1.75 (and confirmed by E3D Support)
McSlappy
Really? How interesting...
Yes, my error. It is 2mm - but it is a crazy rigid 2mm. I've compared both types - the whiter plastic and the clearer version SeeMeCNC uses. It appears that the ID is a bit larger and quite possibly the walls are more forgiving. Does it matter? I'm not sure.elmoret wrote:This is incorrect, as I was CC'ed on the email John is referencing. The ID of E3D PTFE tube is 2.0mm, confirmed by both Sanjay and myself.JohnStack wrote:The ID is 1.75 (and confirmed by E3D Support)
To me, there are two supply chains to solve: Software and materials to the bed. Frustrating weeks of multiple compound failures leaves me scratching my head and not moving my ball forward. (What's your favorite whine? "I want to go to Disneyland!")
I claim V*I*C*T*O*R*Y
I have now printed well over 100 parts - more than 90 of them were parts that I struggled to print without some form of PLA jamming at some time - with absolutely NO PLA JAMMING. The short .5mm nozzle bore is critical I believe. Not only did these parts print perfectly, I was able to print them at reasonable PLA temperatures of 185-190°C and at speeds up to and above 60mm/s. This is the fastest speed and lowest temps I've ever been able to sustain printing with the Kraken. The same "fix" applies to the E3D hot end as they share the same nozzle and basic geometry. I have not heard back from Sanjay and Josh from my original email so I just emailed them again. I'd like to know if they have followed up on this and tried it out themselves and also what their actual bore length spec is for their .4mm nozzles.
In any case, I would really like to see if someone with a jamming problem could resolve it with a shortened nozzle bore without any of the other debuting and polishing fixes we've tried. I am willing to send a bored nozzle to someone with an E3D PLA jamming problem in exchange for them sending me their original nozzle. Or, simply rebore your nozzle yourself with my instructions published a few days ago.
I am now more confident that the long 2mm bore on the .4mm E3D nozzles has been the root of most, if not all, PLA jamming issues. So much so that I am claiming V*I*C*T*O*R*Y!
regards,
regards,
You are a cautious person who doesn't declare victory very often.
Another job well done. I do hope that Josh and Sanjay get back to you on this.
Me too!
I should say that I do think there is still the issue of heat transfer to the nozzle and the combination of the long bore and marginal (IMHO) heat conductivity to the nozzle play hand-in-hand to cause problems. I think this might be why some folks seem to be ok (that and perhaps they are not pushing their printing as much as I and a few others do) -they might be inserting the nozzle "deeper" or not following the instructions to the letter.
I haven't made any changes to impact heat transfer, that will be next if the problem creeps back in.
McSlappy
Well this just made my day!
I've not installed my new e3d yet, but at least I'm now confident that it'll work - if it works for the crazy infills you do, mine should be cake!
Thanks a lot Michael, this sort of information is so valuable and I really really appreciate you putting the hard yards in to work it out!
I hope Sanjay responds, this information is gold!
I would definitely be down for testing out your short bore nozzle, it'd be great to be able to print PLA on my E3D! Sent you a PM.
Let's do it Glacian22. I've replied to your PM.
cheers,
cheers,
A video printing my tenkara line holders on my SeeMeCNC Rostock Max v1 at 80 mm/s on PEI at 50°C. This is the Kraken hot end, PLA at 190°C with my "shortened nozzle bore" mod to the Kraken nozzle.
[youtube]http://www.youtube.com/watch?v=29Y73qZBVdE[/youtube]
I can print all day at these speeds with the Kraken now. I'm also starting to bump up the speeds to see how high I can go. Unbelievably (at least based on my earlier experience) I have not had to bump the temp for PLA up much at all - this is 190°C and I have actually printed at this speed at 185°C but why push it!
All of the rattling you hear are my binder clips vibrating during the sinuous infill. This machine is just amazing!
Here's a pile of finished parts ready to ship:
