Help Designing a part for my vending machine
apostoly
Post by apostoly »
Hi all,
I started playing around in tinercad, seems pretty easy but im a complete novice at 3D designing.
I need to design and print a little cam used in a Drink Vending machine hat has snapped in half.
If i was to take a photo with the complete measurements, would anyone volunteer to design it for me??
Im sure it wont take long, but for me it has taken.... i dont want to say how long, and its not working the way i would have liked.
I know practice makes perfect, but i just need this part so we can get the machine up and running again then i will continue practicing.
Please let me know if anyone is willing to give it a go and i will take photos and measurements for you.
Thanks Paul
McSlappy
Re: Help Designing a part for my vending machine
Post by McSlappy »
I'd be happy to help a fellow countryman - give me some shots and dimensions and all should be good :)
apostoly
Post by apostoly »
Thanks McSlappy
Ill Pm you
joecnc2006
Post by joecnc2006 »
post pictures here?
Joe
McSlappy
Post by McSlappy »
https://www.dropbox.com/s/x2oikj2qb6aeqau/cam.STL
Here's a link to the .stl file. I made a few best guesses on this, and I'm pretty sure that the 'teeth' pairs are supposed to be the same size, but they're not. If you know that they're supposed to be identical, let me know and I'll fix it.
McSlappy wrote:https://www.dropbox.com/s/x2oikj2qb6aeqau/cam.STL
Which Cad software do you use to design as well as you do?
apostoly
Post by apostoly »
When i get home, ill re measure everything and let you know..
Mate, im super impressed. As eagle asked, what software did you use?? I still need to finish building my printer, this will be the first thing i print once its done.
I cant say thank you enough.
Where abouts do you live?
apostoly
Post by apostoly »
I made a mistake and said that the whole diameter was 60mm but in fact side to side minus the teeth is 60mm
Ive let McSlappy know, hopefully its not a pain to resolve
joecnc2006
This Should be very close and work for you.
http://www.thingiverse.com/thing:301507
Joe
apostoly
Post by apostoly »
joecnc2006 wrote:This Should be very close and work for you.
wow, thanks Joe. Looks good mate
Much appreciated!!!
Return to “The Lounge”
