Help Designing a part for my vending machine
Hi all,
I started playing around in tinercad, seems pretty easy but im a complete novice at 3D designing.
I need to design and print a little cam used in a Drink Vending machine hat has snapped in half.
If i was to take a photo with the complete measurements, would anyone volunteer to design it for me??
Im sure it wont take long, but for me it has taken.... i dont want to say how long, and its not working the way i would have liked.
I know practice makes perfect, but i just need this part so we can get the machine up and running again then i will continue practicing.
Please let me know if anyone is willing to give it a go and i will take photos and measurements for you.
Thanks Paul
Thanks Paul
Re: Help Designing a part for my vending machine
I'd be happy to help a fellow countryman - give me some shots and dimensions and all should be good
Thanks McSlappy
Ill Pm you
Ill Pm you
- joecnc2006
post pictures here?
Joe
https://www.dropbox.com/s/x2oikj2qb6aeqau/cam.STL
Here's a link to the .stl file. I made a few best guesses on this, and I'm pretty sure that the 'teeth' pairs are supposed to be the same size, but they're not. If you know that they're supposed to be identical, let me know and I'll fix it.
Which Cad software do you use to design as well as you do?McSlappy wrote:https://www.dropbox.com/s/x2oikj2qb6aeqau/cam.STL
When i get home, ill re measure everything and let you know..McSlappy wrote:https://www.dropbox.com/s/x2oikj2qb6aeqau/cam.STL
Mate, im super impressed. As eagle asked, what software did you use?? I still need to finish building my printer, this will be the first thing i print once its done.
I cant say thank you enough.
Where abouts do you live?
Here are the Pictures i gave McSlappy
[img]http://i1110.photobucket.com/albums/h451/apostoly1/measuredcopy.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140416_183726.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140416_183735.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140416_183807.jpg[/img]
I made a mistake and said that the whole diameter was 60mm but in fact side to side minus the teeth is 60mm
Ive let McSlappy know, hopefully its not a pain to resolve
- joecnc2006
This Should be very close and work for you.
http://www.thingiverse.com/thing:301507
Joe
wow, thanks Joe. Looks good matejoecnc2006 wrote:This Should be very close and work for you.
Much appreciated!!!
