Lego minifig costume parts
stienman
Post by stienman »
It looks like my kids want to be lego minifigures. So I took a few measurements and used openscad to create a lego hand that would be hollow inside so you could wear it like a glove:
http://www.thingiverse.com/thing:31553
Being large, thin walled, and ABS it delaminated in three places during the build (conveniently on the hidden backside) but for a costume prototype it was great.
I'm working on replacing the kapton laminated glass build plate with a kapton laminated thin steel build plate so I can flex the plate to remove large prints, rather than chipping away at the prints. Then I need to build an insulated box around the machine so I can heat the whole interior to 70C and avoid the ABS cracking... I hope. Plus with the steel plates I can remove one, put another one down and start printing immediately while I deal with removing the part and cleaning the kapton on the one I just removed. Should make some builds go much more quickly.
Of course the ideas are not mine - to learn more about the steel plate and heated chamber, read Nophead's posts:
http://hydraraptor.blogspot.com/2010/01 ... e-bed.html
http://hydraraptor.blogspot.com/2010/06 ... rcoat.html
michaellatif
Re: Lego minifig costume parts
Post by michaellatif »
Nice!
Mike Latif
H-1 #3
Fiero2M6
Post by Fiero2M6 »
That part is huge. Awesome! I haven't had the guts to try a print that large yet. How long did it take to print?
stienman
Post by stienman »
Fiero2M6 wrote:That part is huge. Awesome! I haven't had the guts to try a print that large yet. How long did it take to print?
It took just under three hours. It was a 0.3mm layer height, and only two perimeters. I too was surprised it printed completely, I honestly expected it to fail halfway through.
