Yes that's the biggest part of the win, and it applies to all plastics not just PLA, because you can print at lower temperature, stringing is greatly reduced without having to run a lot of retraction.mhackney wrote:I'm running 2mm retracts at 25mm/s with no stringing. I removed all the slop from the PTFE-PTC connections on my Bowden also. Now that I can print PLA at 180-185°C again, there is mush less problem with stringing. I do use a 2mm Z-lift, which also helps.
I still have the original PTFE-PTC connector on the easystruder side, which is introducing some additional hysteresis, so I need a bit more retract.
Having said that it isn't horrible at 2mm, I printed the voronoi easter bunny yesterday and there are some hairs on some of the holes, KissSlicer likely would have been string free because of wipe, Cura however wasn't.
