Prozacs Max Build
Re: Prozacs Max Build
Heres a picture of the hollow pyramid while its printing looking alot better than the other two.
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0263_zpsgwqsp0p0.jpg[/img]
completed (looks like at the top it doesnt have enough time to cool)
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0266_zpsiqhezdif.jpg[/img]
Have the extra bearings from where I didnt use the axle supports , so I decided to model up a better spool holder. Realized that I could have just made end caps now and save material but well see how this fits.
Model
[img]http://img.photobucket.com/albums/v129/ProZaC333/spoolspacer_zps4132a5c3.jpg[/img]
Printing, 4 hr 45 min print at 64 speedrate.
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0268_zps0exsmrm9.jpg[/img]
Model
Got the spool roller going smooth , had to sand a little for the bearings.
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0269_zpsosxk2qdx.jpg[/img]
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0271_zpscpbcx5ij.jpg[/img]
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0273_zpsmrxoav0r.jpg[/img]
- AndThenSome09
Looks like a good idea, I know mine has been printing beautifully since I switched to a spool holder with bearings!
McSlappy
I think a spool holder with bearings will be my next addon, looks good!
Well things got a little messy around my work area , so I took the time to clean up a little and figured while I was at it , it was time to clean this rats nest up. Heres a before and after.
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0311_zpstve4yjk5.jpg[/img]
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0315_zpsge2etuk1.jpg[/img]
- AndThenSome09
Huge difference!! Looks good to me!
Very nice and I like that fan you put on the door to cool the Rambo.
Thanks , I decided to change up a little on the Rambo cooling , added a 80mm fan blowing on the rambo and moved the smaller one to exhaust out.
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0317_zpsyk0avu0k.jpg[/img]
Can the door close in that configuration?
Yeah perfectly and vents the hot air out through the notch. Just hot glued untill I print a mount.
Well I ran another 4 wires down the extrusions for a light ring upgrade/mod to show , should have recorded was funny, I forgot to resist the 5v supply and I watched the 6 leds count down to death , lol.
Heres me testing before install.
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0323_zpskscovdcd.jpg[/img]
Face Palm (what I tested at then hook up to 5v)
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0325_zpsivnephqn.jpg[/img]
Well got off work and took the time , so I woudnt forget the most important part , the resistor. So I wired 6 led 3.5v to the 5v supply on the PSU using a 39 ohm resistor. Heres some pics!
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0326_zpsdnquwlhh.jpg[/img]
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0327_zpsfrhm0kbs.jpg[/img]
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0329_zpsnkpmpoga.jpg[/img]
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0330_zps4gkj7pwu.jpg[/img]
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0331_zpsz8trgxpm.jpg[/img]
and done! Back to printing this encloser , about through with my first spool.
Those leds look great on there and are very functional, good job!
Thanks. I just got some color in , ordered from Justpla.com because seemecnc was out of the PLA trans purple. But I got Green ABS and Trans Purple PLA Fast shipping.
Need to make a spool adapter for them , when I get off work.
Heres a Picture.
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0333_zps7pvuntgl.jpg[/img]
Heres a Picture.
I get the JustPLA from Amazon and never had a problem with them.
Good prices too.
Good prices too.
Good to know , Im looking forward to Laying some PLA down and seeing what kind of results I get.Which reminds me I need to get this PLA Fan mounted and wired up.
Well here's my first PLA print with a matching ABS I printed awhile back. Pla shifted towards the top not sure why.
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0334_zpsmbpyfzqr.jpg[/img]
Well its been awhile , Ive been struggling with random layer shifting , and after tons or wasted time in denial that the extruder stepper wires and endstop had anything to do with it. Mainly after 50 hours of printing I didnt have any problems untill I change filament. But that was the problem I remove the wires from the extrusion and no more layer shifting. I now would like to stress how Noise can effect printing , I should have listened but thought I could beat it.
Little holder I made for work.
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0420_zps7arcaw05.jpg[/img]
BTW Ive been having really good adhesion results with abs on bluetape.
Well after printing some more encloser pieces I decided to take a break switch it back and try out some more justpla trans purple and print a twisted vase,heres the results. No layer fan , but the breeze in this room is tornadict, window unit and ceiling fan on low.
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0428_zpsm43gjzlr.jpg[/img]
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0430_zpspywcusvg.jpg[/img]
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0431_zps13nrb634.jpg[/img]
Looking forward to some upgrades
Carbon Fiber Helm joint arms or magnetic (still researching)
mutliple extruders (more colors and support material)
The all mighty Kraken (Dreams can be great)
Printing another twisted vase thought I would share the current result.
[img]http://img.photobucket.com/albums/v129/ProZaC333/DSC043261_zpsa19172b1.jpg[/img]
That is a great color and a great job!
Thanks guys Im glad to be printing without the noise issues. And looking much better. I decided to get the spool off the top of the max so I printed some supports and mounted above feeds great.
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0448_zpsv1otpwsu.jpg[/img]
