Is there a drawing of the Onyx plate available?
I'm looking for something that I can give to a shop to fabricate a aluminium plate for a heat spreader and would like to have the bolt hole drilled as part of the build.
						Aluminium Plate
Re: Aluminium Plate
The dimensions are listed in the details on SeeMeCNC's website. I believe it's 310mm overall with 6 holes at 300mm...     Go check for sure, but I think that's what it is.
*edited with exact values*
					Last edited by Jimustanguitar on Fri Apr 25, 2014 2:59 pm, edited 2 times in total.
						Re: Aluminium Plate
You are right. Thanks.
310mm Overall diameter
Six 3mm diameter mounting holes spaced on a 300mm diameter pattern
Jimustanguitar wrote:The dimensions are listed in the details on SeeMeCNC's website. I believe it's 300mm overall with 6 holes at 280mm... Go check for sure, but I think that's what it is.
Re: Aluminium Plate
a file exists on the forum for the exact shape including the notch at the top needed.
						Re: Aluminium Plate
here one I drew up a while ago.. should still be useful.. same one i used to make mine.greenlee wrote:Is there a drawing of the Onyx plate available?
