Yes I have calibrated a number of times to get it as close as possible, and I don't believe the Z height was too far off the base. I used Gunau's advice here after trying the calibration procedure in the manual:
http://forum.seemecnc.com/viewtopic.php ... 985#p36589
For some reason I had issues with the calibration outlined in the manual, but Gunau's advice got me pretty darn close...I think.
Secondly, the extruder was set to 225C and the bed was set to 95C.
Finally, the Aquanet worked great. Probably some layer alignment issues to work on now, but you tell me what you think. I did just notice that the nut holding the extruder, right above the melamine spacer, was loose. I think I just hand tightened that originally when building the printer, as I was afraid to damage anything. I just now tightened that up snug with a wrench and expect that will get rid of some of the layer alignment issues.
Here's the print. Note: It might not look 100% flat on the bottom, or look warped, but it's not...the fan is protruding out of the bottom just a bit causing it to lean. The fan went in with no filing required too. It's snug, but I expect that's intended.
- Fan installed
I added another topic about the print here:
http://forum.seemecnc.com/viewtopic.php?f=77&t=5233
Thanks again for all the guidance so far man! I appreciate it.
