Printrboard Power Resistor
eekflyer
Post by eekflyer »
For those using printrboards, what hot-end power resistor are you using? 100K Ohm for the H1.1?
TIA!
johnoly99
Re: Printrboard Power Resistor
Post by johnoly99 »
eekflyer, you mean thermistor. Yes, you need a 100K thermistor for a printrboard. The Resistors are the part that create the hear, and they are 6.8 Ohm 3Watt, where as the thermistor READS the temperature and sends it back to the board, and it is 100K Ohm
eekflyer
Post by eekflyer »
Thanks, you answered my question. I actually did mean hot tip resistor but stated the wrong value! I still got it wrong. All better now!
Return to “The Build Zone”
