trouble with the klcd screen
Dad003
Post by Dad003 »
HI,
i bought a rostock max v2 , the assembly was going good , now i have a problem the lcd screen still have power and bip when you turn on the printer or pres the button but i have only 4 line of block and nothing else , it show noting i checked the adapter and look good switched the large wire and all is good , but the lcd still show only 4 line of bar , anyone one have an idea about the bug ? or it just a scrappy lcd , because if i look at repetier i have the .91 for firmware printer work like it supose to be
i have send a email for support about that and a missing thermistor an waiting for a answer , may be someone have a solution if it just a bug
McSlappy
Re: trouble with the klcd screen
Post by McSlappy »
You sure about the connector? When I put mine together I marked, checked and rechecked the LCD cable. Still it turned out that I had it plugged in upside down.
I would get beeps, but didn't get much on the LCD so it may not be the same issue as yours, but worth a check.
Elysio
Post by Elysio »
Hi
Still have a similar problem, waiting for answers.
http://forum.seemecnc.com/viewtopic.php ... 4&start=10
Bye.
sandy
Post by sandy »
I had this problem, too. If you stand completely to the side of the circuit board(perpendicular to it) and look down the side at the screen - can you read any of the characters? If so, your potentiometer is turned way, way too high.
If you look at the back of the board there is a tiny potentiometer that you can adjust with a screwdriver.
If you turn it to the right 1/8-1/4" the screen should get brighter, so bright in fact, that you cannot see anything (white-out)
If you turn it the same amount to the left (1/8-1/4") and it just goes dimmer but the blocks are still there, then try turning it as far as it will go to the left.
It should go completely dark. Now, a tiny bit at a time, turn it to the right. Eventually it will be dimly readable. Now just adjust brightness to taste.
I found this when I was sitting perpendicular to my lcd panel and trying look at something across the room.
-sandy
Dad003
Post by Dad003 »
my problem dont seem to be the brightness i tried to change it but nothing
[img]http://www.servimg.com/u/f57/11/37/22/78/img_2013.jpg[/img]
what my lcd look like
esbowman
Post by esbowman »
I had the same problem, so I removed the LCD screen thumbscrews and propped it up. Turned the printer on and used a tiny screwdriver to adjust the contrast pot on the back of the LCD screen. Once I turned it a few times I could start to read the two rows of dots perfectly. In my case I could see nothing and thought the screen was dead. If you need a pic of the pot I'm talking about let me know.
