After putting in my 2nd thermistor I got some great test prints for various filaments, ABS, PLA, WOOD, Bridge...  The first thermistor died after a couple of hours of printing.  The second one gave me 20+ hours of printing before it slowly started to give false values.
It started when a nozzle jammed from too much heat raising up in the hotend, and the filament got wedged in the PETF tube.  I cleared that and let the printer cool down.  Or so I thought.  I step away for just a few minutes, came back, and the temp read 27C.  It previously read in the 200C-220C range.  It didn't click that it cooled off way to fast.  But I don't have a great sense of time to begin with.  So needless to say I have 2 small burns on 2 fingers.  As the printer continued to cool off it dropped down to -19C.  Which was pretty impressive, and a clear sign of a problem.
I noticed extra blackness around the nozzle, so I took the hotend (now cold) out of the printer and realized the power resistors are now very loose.  I went further and took them out, and cleaned up the RTV.  Both resistors have melted spots, and crackes in the cases.  And the hotend feed tube insulator bent a a little!
I think the thermistor went bad which caused the board to keep applying power to the resistors, which over heated the hotend, which melted the feed tube insulator a little...
I might be down a bit, but the bird feeder was coming out great!
-Max
						Thermistor died, over heated hotend
- foshon
Re: Thermistor died, over heated hotend
Those resistors cracking is normal. The rest is an issue.
							Purple = sarcasm
...and the resistors should be replaced!
Got the new hotend, resistors, thermistors, etc, assembled and printing.  After a Z calibration, it's off and running just as smooth as before.
I found the original problem. I had the fan wires switched, so the hotend/filament cooling fan was not coming on, except when the model needed cooling. <Smack forehead>
I took time to glue the spool holder arms to each other, and touch them up on a sander to give them a nice curve. Then added clear smooth packing tape around where the spool rides. It just glides off, no clunking.
-Max
-Max
