Bigger print length?
Recently got a 10"by 7" sheet of glass for my printer and was thinking, If I moved the bearing assemblies and belt clamps closer together then I would be able to print bigger area correct? Any drawbacks? I was thinking that the just couldn't be too close or else they would wiggle.
						Re: Bigger print length?
If you're worried about getting the bearings too close, extend the rods outside the front or back and put an additional set of bearings out there, and make the table longer.
Naw I dont want a bigger build area that much just looking for any easy thing to do , I'm using linear bearings also
