Can't connect to Rambo
forrie
Post by forrie »
Hi,
I've just finished my build of the v2 and I'm have issues.
The printer powers up but I have two problems. First - the LCD screen doesn't work, and Second - I can't communicate with the Rambo.
The USB driver has installed fine and I can see the port correctly, but I get the following when trying to clear the EEPROM:
Binary sketch size: 1,348 bytes (of a 258,048 byte maximum)
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
Everything seems to be connected correctly and the Rambo fan is spinning...
When I upload the orange led on the board flashes 6 times about 10 seconds apart.
Any idea's?
JohnStack
Re: Can't connect to Rambo
Post by JohnStack »
You probably have wired the LCD incorrectly. Check that.
As for connecting, you didn't say if you had a PC or Mac. You will either need drivers (did you install them) or alternatively change your baud rate - on both the printer and the software.
119,200 works ok for Macs. PCs can handle higher speeds.
http://dropc.am/p/KhiI1a
forrie
Post by forrie »
PC - Windows 7, I have the usb driver installed and I tried reinstalling it.
I've tried all the different baud rates and still the same problem. I've also tried with the printer powered on and off.
I guess some level of communication is going on with the board as the orange led blinks during the upload process.
Are there any other led's I should see on the board? I read somewhere there should be a green power led? I'm not seeing one?
forrie
Post by forrie »
:oops: Well this is embarrassing :lol:
I guess when I installed the Rambo one of the power leads worked its way loose on my modular PSU. I had no power going to the board....phew.
My multimeter saves the day again.....Crisis averted!
Everything is working - yippie!
