I still haven't succeeded in getting the fan housing (ABS) to build completely - it keeps coming detached from the glass in the early part of the print. If anyone has had similar troubles (and resolved them) I'd appreciate any advice.
1. I wonder if anyone has seen the following problem:
The bed temperature goes up very slowly, and does not get any higher than about 80C, although it creeps up very very slowly after that. After over an hour it is still around 80C (with a target temperature of 90C). I have run the PID routine for the extruder and for the bed, averaged the values and put them in the EEPROM. The extruder gets hot reasonably fast (over 200C), but not the bed. What can it be? Do I need to double up on the 18 gauge wires powering the bed heater? Shorter wires? Change some other settings in the EEPROM?
Also:
2. Where is a good place to buy that purple glue stick that is recommended (I used very thin 2-sided tape, did not work (at 80C))?
3. When printing ABS, is it okay to use Kapton tape on the bed to protect it from gumming up?
I'm really enjoying my new 3D printer!
