Keep losing my balls.
626Pilot
Re: Keep losing my balls.
Post by 626Pilot »
Can you solder the balls to the screws? It seems like it would be a comedy of errors unless you had a real good grip on that iron.
edward
Post by edward »
626Pilot wrote:Can you solder the balls to the screws? It seems like it would be a comedy of errors unless you had a real good grip on that iron.
I would say no, but here is someone that did: https://groups.google.com/forum/#!searc ... TpB2oSBrEJ
I'm not sure what kind of solder he used, but most solder is not meant for tension applications, especially "electronics" solder, which doesn't have very good strength properties to start.
notarat
Post by notarat »
What size are those balls you guys JB Weld to the screw heads?
Just wondering because I found some ball studs that might possibly be used if they're the right size.
[img]http://www.beadlok.com/product/images/5 ... SC6275.jpg[/img]
gestalt73
Post by gestalt73 »
I've been running with loctite ultra gel control for months now in a heated build chamber, and haven't lost a ball since I switched over.
[img]http://www.loctiteproducts.com/img/prod ... _cntrl.png[/img]
lordbinky
Post by lordbinky »
Flateric wrote:If someone has found a fast easy and cheap way of drilling and tapping steel ball bearings, PLEASE speak up and tel me how you are doing this. Because I cannot see this being, fast, easy, cheap that I can think of.
Find someone with an EDM machine? Hm... that'd be a neat attachment for the rostock....
notarat wrote:What size are those balls you guys JB Weld to the screw heads?
What is the source on the balls? We already had a post about the traxxas balls and those look very similar.
Eric
Post by Eric »
Imagesearch leads me to these sites:
http://www.teamassociated.com/parts/details/6275/
http://store.rc4wd.com/Associated-Balls ... _2276.html
Neither page says what they're made of, so no idea if they'll stick to a magnet or not.
They also do not give the diameter of the balls which is the most critical aspect.
They are #4 nuts which I believe are 1/4 inch in diameter, so the balls are probably < 6mm.
Polygonhell wrote:They are #4 nuts which I believe are 1/4 inch in diameter, so the balls are probably < 6mm.
Good point, and I already have the Traxxas balls that are on the stud so I'll keep my plans to use those.
Post by Mac The Knife »
these would be around.375 diameter,,,, http://www.stormerhobbies.com/cgi-bin/s ... n=OFN36903
Flateric
Post by Flateric »
I could be wrong, but the balls pictured there, look very aluminium....?
Flateric wrote:I could be wrong, but the balls pictured there, look very aluminium....?
That is the problem with the Traxxas balls, they are sold in both the aluminum and steel versions and you have to be sure
what you are ordering. The steel versions work perfectly with the magnets, just be careful what you are ordering.
