I've spend some time to find some info about *subject*, without good results at the moment. All I know at that moment is that one will need to different board (discussed there http://forum.seemecnc.com/viewtopic.php?f=35&t=5374, for example) to make that real, that's all.
What about mounting? Does anybody have working solution on the table or in mind?
Triple fullmetal hotends solution for Rostock MAX v2
- Renha
3D printing is magic!
Re: Triple fullmetal hotends solution for Rostock MAX v2
If you're going to go with 3 hotends, may as well go with the Kraken, no? Just seems like it would be the easier, and quite possibly cheaper route, depending on the hotends. But I'm curious too. I'd really like to go multi-extruder when I get this ONE dialed in. I worry about oozing though, already a mess with just one.
- Renha
Yep, 4 hotends would be great too. Could you give me good link to read about Kraken? All i've found is YouTube video
Another question, is extruders and filament pools mounting, i'm not imagine how to place them onto v2 of Rostock MAX
Mhackney is probably a good person to talk to about this, he's got a kraken running on his V1, you can check out his build thread in the build zone
- Renha
Thank you Mike, i'll check it
Yup, lot of good discussion on it. https://www.google.com/search?q=site%3A ... 2&ie=UTF-8
p.s. I have the overwhelming temptation to make my avatar a pony right now!
- Renha
wow, I wasn't smart enough for such a trick, thank you very much!
p.s. that would be great, I think
