Okay, this is weird. I ended up missing 2 x 1" Pan Head screws. What is really weird is this is the step where you mount the brackets to the display board. However, I have a bag with 2 x 1" Flat Head screws and 2 x nylon/steel nuts. So is this just a case of a screwy mix up?
I don't need the pan head screws as I have some 1" pan heads with a flat head (non-phillips). So those will work. I figured I should mention having 2 Flat Heads instead of 2 Pan Heads.
Also, the other weird thing is I searched the entire manual and never once does it mention 1" Flat Heads even being used.
Missing 2 x 1" Pan Head Screws
- Demolishun
- nitewatchman
Re: Missing 2 x 1" Pan Head Screws
Used the Flat Heads on mine and didn't look back.
nitewatchman
nitewatchman
