Noob question about estimated print time
- Ricky_Spanish
- Prints-a-lot
I'm doing my first decent sized print. I sliced it with Cura, which is what I've been using most often, and for some reason it was skipping the same line in the base layer no matter what setting I used. No problem, switched to Slic3r/Repetier-Host. Now the problem: a 10 hour print in Cura is showing 123 hours in Slic3r
. I could carve this piece out of whale bone with a toothbrush in 123 hrs. My question is, how accurate is the estimated print time in Slic3r? Is this a common issue?
Re: Noob question about estimated print time
link to the file and ill test the time out
- Ricky_Spanish
- Prints-a-lot
It's a model I designed, do you need the gcode from Slicer or the STL? Sorry for not following some of this, I haven't dealt with CNC for about 6 years, a lot has changed. lol
stl will do
- Ricky_Spanish
- Prints-a-lot
Here it is. i think it's just being crazy on estimates. It also estimated 225 meters of filament, and this shouldn't take over 40. I timed the last 2 layers and I'm figuring around 10 hours, give or take.
- Shaberts rack.stl
- (86.31 KiB) Downloaded 293 times
21 hours, 30mm/sec, .3 layer height, .4 nozzle, 10% infill, 3 perimeters,3 solid top/bot
- Ricky_Spanish
- Prints-a-lot
Awesome. Thanks. A lot better than 123 hrs. lol
- Captain Starfish
Generally I now only look at the Slic3r estimates (actually, all of them) for a laugh. Takes as long as it takes. If I have a somewhat time sensitive print I'll stopwatch the first few layers, scale to whether they are more/less full and complicated than the "average" layer of the model, and multiply out to the number of layers to get an idea.
- Ricky_Spanish
- Prints-a-lot
I'm learning that. Back in the day, I worked with BobCAD/CAM and Haas machines, and you could set your watch by the ETC, so this just threw me for a loop.
