Hello everyone.
I am about 8 to 10 hours into the build of my Rostock Max v2. I own a Thing-o-matic (from back in the day), and although my TOM is till working good, it needs a size and hot end upgrade. I really want to try a delta printer and the MAX v2 has everything I want - comes in a kit, good build size, open source, and what looks like a great community.
On a different note, I also own a Shapeoko 2 and I am a beta tester for Inventables Easel. I really like what they are trying to accomplish. Always interested in Shapeoko ideas as well. Currently have a laser engraver, printed drag knife, and multiple spindles working.
OK, so actually the v2 build is going quite well, but although I lined up the two plates of the cheapskate, when I completed the assembly I had put the u-joint carrier on the wrong side so the carriage is reversed with the eye's looking up to the left versus up to the right. When I caught it I tried to remove the u-joint spring clips but they are difficult to get off the axle and I cracked one of the clips, so I am afraid to damage them more. I installed the carriage assembly as is and they seem to work well and align acceptably. The question is can I leave them like this, or will this cause trouble later on down the line especially with calibration?
So my options:
1. Install as is but mirrored
2. Take my chances and try and remove/reverse the assembly (any advise on the easiest way to get the clips off?)
3. Order new cheapskate assembly
Any advice?
Look forward to sharing with everyone.
Thanks,
Mike
Hello from Crystal Lake, IL
Re: Hello from Crystal Lake, IL
If you leave it as is it is going to forever bother you because you know that it is not right.
I would reverse the assembly and have support send you new clips that you break. You can email them at [email protected]
It may make you feel better if you knew that you are not the first to do this, it is a common mistake.
Thanks. Good advice. After walking away from it I figured out a simple way to disassemble without stressing the parts. Your right it would have driven me crazy in the future.
Back on track. Thanks for your reply.
Mike
Mike
That's just being human. I'm glad you are back on track.MikeD wrote:Thanks. Good advice. After walking away from it I figured out a simple way to disassemble without stressing the parts. Your right it would have driven me crazy in the future.
Mike
