hot end salvageable?
mmorgan11
Post by mmorgan11 »
So, I ran auto-tune and all was well, then I turned up the temperature to begin calibration and as I got near the base, the hot end started smoking a bit. I shut it down, but I think I was too late:
Is this salvageable or am I in the market for a new hot end?
Upon further inspection it looked as if the thermistor had come slightly loose on one side but still attached to the hot end...Is this it or could it have been something else?
Thanks,
Marc
Re: hot end salvageable?
You can order a new piece of PEEK (the gray plastic in the middle) from SeeMe, and it'll screw between the top and bottom pieces of aluminum no problem.
Are the heating resistor and thermistor ok?
mmorgan11
Post by mmorgan11 »
Ok, thanks...found the peek
The heating resistors seem fine...How would I know if those were bad?
The thermistor acted a little strange when I turn the system back on. It read -8 C for a little while and then came up to room temp. Should that be ok, or should I replace that too?
nitewatchman
Post by nitewatchman »
You might seriously consider a Screw In Mounted Thermistor. The RTV itself is a bit of an insulator and not a real good adhesive. I followed Gene's YouTube upgrade and went to a 40W Cartridge Heater and M3 Screw In Thermistor in the initial assembly. Also wrapped the Hot End with Silicon Tape. Parts from eBay.
http://www.youtube.com/watch?v=xvXKt3xDt4E
nitewatchman
Yeah, the screw-in thermistors are just awesome. If you don't have the desire to do the tapping, etc, at least wrap the hot end with the silicone wrap. It'll go a long way toward keeping the thermistor in place.
mmorgan11
Post by mmorgan11 »
Man, I wish there was a link to that in the guide...would have done that from the start! :/
How do I remove the damage peek, just twist left?
nitewatchman
At times the use of Energetic Material may be required to remove the offending part.
Just get someone to hold your beer while you light it.
nitewatchman
