The only way to clear the nozzle is to remove the nozzle and head to the stove (gas flame) and boil and clean out the PLA that remains inside the nozzle.
This brings me to my second problem by the time I cleared things up I couldn't restart the print, controlling the printer via Repetier was impossible nothing worked so I give up on the print and try to kill the job but it had no effect on the printer. I tried to use the kill switch on the printer and there is no response. The only thing left to do it to turn off the printer.
This leads to a third problem, when I have to turn to the switching off the printer in this situation then the power supply won't switch back on because it is over heated so I have to whip out the can of air to cool things off in the back of the supply and then the machine will switch on.
Any advice will be greatly appreciated!
