man sized
bubbasnow
Re: man sized
Post by bubbasnow »
i made these, i used some carbon fiber arrow shafts i got from a sports store. Im using s3d, no retractions, no lifts and going slow.
Re: man sized
bubbasnow wrote:i made these, i used some carbon fiber arrow shafts i got from a sports store. Im using s3d, no retractions, no lifts and going slow.
Would it be possible to get the STL file that S3D created and the outside diameter of the arrow shafts? Thanks Bubbasnow.
bubbasnow
Re: man sized
Post by bubbasnow »
ring.STL
(51.25 KiB) Downloaded 456 times
magholder1.STL
(271.18 KiB) Downloaded 381 times
Re: man sized
Excellent, just what I was looking for. Thank you so much.
I have one more question before you get mad enough not to talk to me again.
Is the effector you show one of the ones that has been posted on the forum or is it your design?
You already know what my next question will be, the STL. Thank you Bubbasnow.
bubbasnow
Re: man sized
Post by bubbasnow »
Not posted yet. I haven't finalized anything yet
Re: man sized
bubbasnow wrote:Not posted yet. I haven't finalized anything yet
Thanks for the other files!
bubbasnow
Re: man sized
Post by bubbasnow »
note that these are for this 'man sized' printer not rostockMax
Re: man sized
bubbasnow wrote:note that these are for this 'man sized' printer not rostockMax
Noted, but the rod ends will work with the proper effector for the Max, and what I was looking for is the rod end that
I could print correctly. I have been having a bear of a time printing the rod ends that would fit the Traxas balls.
bubbasnow
Re: man sized
Post by bubbasnow »
and progress
[img]https://lh5.googleusercontent.com/-AxLG ... 002640.jpg[/img]
yup thats a yard stick on the build height, soon ill hook up the electronics and get to cracking with linuxCNC on my BBB
Gr8Scott
Re: man sized
Post by Gr8Scott »
Bubbasnow - What cape are you going with on this? I just ordered a CRAMPS PCB and intend to populate it later on when I get around to building my very own "man sized printer" like yours. Basically I'm gonna emulate ya. Would you mind sharing files etc with me later if and when I get everything soldered together and tested?
bubbasnow
Re: man sized
Post by bubbasnow »
i got a bebopr plus plus, yea once i get this thing dialed in ill post my stuff
Eric
Re: man sized
Post by Eric »
You should glue the yardstick on permanently; it's an interesting trim piece, plus answers the first question about size. Besides, it could be handy for measuring the odd item.
bubbasnow
Re: man sized
Post by bubbasnow »
Tinyhead
Re: man sized
Post by Tinyhead »
I'm a bit glad to see now that the printer isn't as gigantic as I once thought it was. In the first pictures, the effector arms looked crazy long and flimsy, but the later pictures/video now looks like an oversized kossel. To me the original was humongous... but now it looks reasonable. Looks good too. Can't wait to see what it's capable of.
Eric
Re: man sized
Post by Eric »
It's alive!
Why did you mount the limit switches so low? It looks like you have more height available.
bubbasnow
Re: man sized
Post by bubbasnow »
Eric wrote:It's alive!
Purely for test.. I didn't want the carriage blowing past and ramming the top of the frame
bubbasnow
Re: man sized
Post by bubbasnow »
important dimensions
[img]https://lh6.googleusercontent.com/-Ji_7 ... 223944.jpg[/img]
all together
https://plus.google.com/112937153117031 ... SpSdjZpi6Q
movement with linuxCNC and BBB w/BEBOPR++
Demolishun
Re: man sized
Post by Demolishun »
That looks awesome dude!
Please give us final dimensions on build area. I might want to duplicate this. Again, awesome work. It looks very beautiful.
bubbasnow
Re: man sized
Post by bubbasnow »
rethinking the endstop adjustments
[img]https://lh5.googleusercontent.com/-Wdwa ... 121916.jpg[/img]
barry99705
Re: man sized
Post by barry99705 »
bubbasnow wrote:rethinking the endstop adjustments
Now that's cool!
bubbasnow
Post by bubbasnow »
[youtube]http://www.youtube.com/watch?v=ASnN7lhQbBQ[/youtube]
ITS ALIVE
Renha
Re: man sized
Post by Renha »
I can't see anything, youtube says it's private video
3D printing is magic!
bubbasnow
Re: man sized
Post by bubbasnow »
Getting things dialed in....: http://youtu.be/ASnN7lhQbBQ
JohnStack
Re: man sized
Post by JohnStack »
I can't see it but geesh, you are the maker I want to be...
http://dropc.am/p/KhiI1a
Re: man sized
bubbasnow wrote:Getting things dialed in....: http://youtu.be/ASnN7lhQbBQ
The video is Private. Can you fix it so we can watch it? Thanks! :)
