22ga wires too short?
Kenshh
Post by Kenshh »
So I'm almost done with the assembly side of the build but the one problem i've come across is that the wires that connect to the print head are too short.
Even when only an inch of wire is left at the bottom of the aluminum post, the furthest down i can get the wire to reach is about half way.
Surely that isnt enough since that would mean that the head wouldn't be able to reach the printer's base plate?
Any help or advice on this would be a huge help!
Re: 22ga wires too short?
Ken, you need to contact [email protected]
Kenshh
Post by Kenshh »
Oh okay
richardphat
Post by richardphat »
The wire should measure about 10 feets, however, I only received 4 feets 1/2. I went to some shop and bought 4-22 gauge. Since I need it asap, I went to the shop and grab some extra wires.
Return to “Rostock MAX v2”
