Well, I've finished the design of the mount, but I'm having a real issue lining up the hotend, bottom section, and top section together. They all fit on their own, but once I put it all together, it's a no go. It has to do with the shrinkage. I've printed about 5 revisions after playing with dimensions and such, but I'm still having issues. Tomorrow I'm going to try moving one of the mounting holes slightly lower, hopefully that'll do it. But it seems like the adjustment's going to work just fine once I can get it all fitted. It'll require 3x M3 screws, I think 10mm will work. I have only 6mm and 20mm, the 6mm's are too short, the 20 way too long. It'll also require 3x M3 nuts, 3x M3 lock nuts, 3x M3 ~12mm to mount to the effector.
End product:
[img]
http://i.imgur.com/P8O8sa2.jpg[/img]
I'll be posting the STL's once I get the measurements down, but I'm not sure which to post, as I'm sure everyone's going to have varying degrees of shrinkage.
I'm wondering if it's okay to print this in PLA. It SHOULDN'T really be in contact with heat right?
Still going to work on the layer fan... been learning a bit more of Solidworks. <3 Lofted Boss / Bass.
I've also picked 60mm angel eyes, so I'll be creating a mount for that as well.
