Hot End On LED stays lit.
I'm finishing up my build of the Rostock Max V2 with the new heatbed that includes the LED light for the Hot End. No matter where I plug in the 2-pin connector on the RAMBO, the Hot End On LED stays lit. Anyone else run into this? I wired it according to another post on this forum.
Re: Hot End On LED stays lit.
Grab the latest drop of the manual (done a few days ago) and go through section 5C.
The 2 pin connector has nothing to do with the hot end LED - that's the thermistor signal wire.
The only time the hot end LED should be lit is when you're actually powering your hot end. Please check your wiring.
Thanks, geneb. I didn't know they released the new version of the PDF. That is exactly how I wired it.. I must have crossed terminals somewhere, I will check it out after calibrating the rest of the machine. Not too worried about the LED at the moment.
