**SOLVED** Extruder Gear Moving back and Forth NOT Rotating
FDM_Process
Post by FDM_Process »
I'm at the part of the build where it asks me to hit the extrude button and that it should rotate counter clockwise. It moves back and fourth a couple mms in both directions instead. I have unassembled and reassembled it. Not sure what the problem is here.
Last one for the day, I swear.. and thank you for your help.
EDIT: Solved this by taking the front panel off and checking the wiring for the extruder motor. The crimps were not pushed all the way into the 4 pin connector.
Re: **SOLVED** Extruder Gear Moving back and Forth NOT Rotat
FDM_Process wrote:I'm at the part of the build where it asks me to hit the extrude button and that it should rotate counter clockwise. It moves back and fourth a couple mms in both directions instead. I have unassembled and reassembled it. Not sure what the problem is here.
It's always the little things that get ya!
Glad you found the problem and got it fixed.
McSlappy
Post by McSlappy »
I had the exact same problem and for me my stepper must have been wired wrong internally since I swapped two of the wire pairs around and it worked fine.
So if the pins are good, might be worth checking that - anyone else who has this same issue.
