GeraldO wrote:So far, no, I haven't put any heatsinks on any other part of the machine. I'm currently testing out a hypothesis with the extruder stepper motor itself but I'll let you know if it pans out.
Good to know, let me know!
On the other hand, my Rostock Max V1, has a lot of heat seated on the Rambo due to multiple reasons:
1.- No Fan at all!
2.- Due to a switched piece during the build (I need to rebuild the entire rostock to fix it!), doesn't even have a "hole" in the back, so, all heat is seated in it.
3.- I usually I print outside the printing bed so I need a little more "grip power" on the stepper motors, which made me increase the current for the steppers,
4.- PLUS large prints +15 hours.
Still, I get very good prints out of it!
I am guessing that, once I reduce all the heat factor, the print quality should increase and get even better
I will be able to compare V1 vs V2, and see what happens
