RegB wrote:About 0.5 to about 0.6 with the standard disclaimer about Harbor Freight precision/quality tools - - we used to say Heath Kit, or Radio Shack (-:
So, if I can remember how to do this;
0.8 Ohms draws 12 Volts/0.8 Ohms = 15 Amps for a 180 Watt draw.
0.6 Ohms draws 12 Volts/0.6 Ohms = 20 Amps for a 240 Watt draw.
Ignoring internal resistance of the supply, which is OK if it is reasonably well regulated.
Guess, guess, guess... That might well justify the next size power supply and would allow significantly faster heating.
Cold spots ? I don't know, that probably depends more on how evenly the heating wire track is spaced across the area - spaced with respect to heat loss.
Edges and center are likely to dump more heat per sq cm., so need closer spacing.
You are absolutely right on the power calculations. However, the 12V line drops about 1 volt, when it is loaded, because this kind of power supply expects the 5V line to be loaded, which it isn't by default. I've loaded the 5V line with some fancy LED lights, so the power supply is somewhat more stable. This is besides the point... it seems your rev. 6 Onyx has a lower internal resistance than my rev. 5, so it will draw more current and get hotter. Of cause there will be some tolerances on both your and my resistance measurement, but it seems like the higher resistance is indeed the problem with my Onyx.
Regarding the 550 W PSU: Mine is the "old" 450 W, and it can provide 28A from the 12V line. I believe the current consumption from a 0.6 ohm Onyx will be too close to the PSU limit (the hot end requires about 3.3 A, and then we have the steppers in addition to that). So, I could be wrong, but I think SeeMeCNC made an active choice, when they choose a bigger PSU with the new Onyx.
It will be interesting to know how they will solve my and others problems with the Onyx, if a new PSU is required in addition to the new Onyx. I wrote them a couple of days ago, but I have yet to hear from them
