Mac The Knife wrote:Seemecnc does offer blank nozzles that you can drill yourself. As for removing the nozzle, I've done it both hot and cold. There is a Teflon liner that keeps the plastic under control somewhat.
Yeah, I know, but I have some brass lying around begging to become nozzles
I took a deep breath and removed the nozzle, which turned out to be no problem. So I measured everything I could and modeled it. However, there are a few measurement that I couldn't do inside the nozzle, because it was filled with plastic. I have attached a drawing with two questions for you guys. Hopefully you can help me out to finalize the drawing. I will post the drawing and model, when I have all dimensions in place.
Thanks in advance!
