Art's *new* RostockMax V2 (Aka Night Fury!)
artexmg
Post by artexmg »
I got my *NEW* V2 kit this past weekend (great!).
I ordered it black, as I like the combination of black-red-yellow, so, I started by painting the pieces accordingly.
As you can see on the pictures, this paint work was done at night ;-)
before
before
after
after
more
more
now red
now red
everything painted, ready to be peeled!
It is so exciting building a new kit again, after so many advances since the original one!.
artexmg
Re: Art's *new* RostockMax V2 (Aka Night Fury!)
Post by artexmg »
Did anybody noticed the little pinky piggy in the last picture? :-)
artexmg
Post by artexmg »
And, here is the before and after peeling ... I like it!
Ready, set ...
Ready, set ...
Peeled!
Peeled!
And I am ready to start building!!!!!!!!
astroboy907
Post by astroboy907 »
Thats gonna be a beautiful machine...
Flateric wrote: Black ABS, weak part, bizzare holes, bad layer adhesion, loss of details. Loss of sanity.
My Heatware!.
artexmg
Post by artexmg »
astroboy907 wrote:Thats gonna be a beautiful machine...
Thanks man, I hope so!
artexmg
Post by artexmg »
Making progress, these are the first steps in the building manual (by the way, thanks geneb!)
power source mounted
I already like the colors.
Can't wait to see the completed printer.
You're welcome. I love painted builds. :D
McSlappy
Post by McSlappy »
I was pretty miffed with myself when I realised I'd forgotten the paint job halfway through our build :(
GeraldO
Post by GeraldO »
The colour scheme looks pretty cool for this one!
Providing humanity its only hope when the robot revolution begins: http://www.anti-robot.com/! Join the anti-robot revolution!
artexmg
Post by artexmg »
GeraldO wrote:The colour scheme looks pretty cool for this one!
Yes! I like Yellow/Black/Red ... maybe some leds?
artexmg
Post by artexmg »
Installing the Motor Dampers (from Tricklaser ;-) )
With and without damper
See the difference between the two motors
The motor with the damper is "higher"
To compensate the width added by the dampers, you will need to place the Hobbed gear not aligned, as Geneb's manual indicates, but a little up.
Pulley perfectly aligned with the belt path (I jumped some steps ahead!)
Everything in line
Everything in line
Belt Path
Follow the yellow path (Oz?)
Be sure to place the damper in the screw, as well as washer, (first washer, then damper)
Be sure to place the damper and washer!
artexmg
Post by artexmg »
This is the gap that has to be left to compensate the width of the dampers. If not, then the pulley will not be aligned with the belt.
See the gap, to compensate the damper!
This close or is OK? :-)
Close look
Close look
All step motors ready on one side
ready!
ready!
And now ready on the other side as well
Set ...
Set ...
... and now, steppers mounted all the way in their place ...
Go! all stepers mounted in the base ;-)
Diferent Angle
Diferent Angle
artexmg
Post by artexmg »
It starts to get the well known, good Rostock Max shape!
Angle 1
Angle 1
Angle 2
Angle 2
Angle 3
Angle 3
I'm loving it! (humm .. now I am hungry!)
artexmg
Post by artexmg »
Eaglezsoar wrote:I already like the colors.
Thanks! I need to hurry up!
imagebuff
Post by imagebuff »
That is looking great Art! Mine is scheduled to show up on Monday. Of course it just missed the weekend.:cry: I'm evaluating a stand to place it on. Would you mind throwing a tape measure on your base and giving me the dimensions?
By the way we are definitely fairly close considering 99 opened up. We need to meet up one day and fly or print or both. Keep the excellent build pics coming as I can use all the help I can get.
Chris
GeraldO
Post by GeraldO »
I'm still trying to decide on which LEDs to use for mine but I chose a similarly loud colour scheme ;) http://forum.seemecnc.com/viewtopic.php ... 8&start=40
artexmg
Post by artexmg »
imagebuff wrote:That is looking great Art! Mine is scheduled to show up on Monday. Of course it just missed the weekend.:cry: I'm evaluating a stand to place it on. Would you mind throwing a tape measure on your base and giving me the dimensions?
Chris
Today is Monday, so, chances are you already have your kit!
I am at work right now, so, cannot provide the measures, sorry. I guess when get back home, at night, you already had figured out the space. However, I you do not need a big space to work, including the printer. By guessing, I think it would fit in a 2ft x 2ft square. Maybe 1.5ft x 1.5ft :-)
Spoiler Alert: I just finished the build, but need to keep up uploading all the photos!
Sure, we could meet, print and fly (FPV print??) :-)
artexmg
Post by artexmg »
Yours look nice! a couple of LEDs would make it even great. I like the blue-ish color of the Ultimaker on the layer fans, and something else, maybe purple? in the towers. Will see.
I have a V1 in Acrylic, I was thinking in upgrading it to V2, but then I decided that it looks great the way it is, so, I will leave it alone. A old pic: http://forum.seemecnc.com/download/file ... &mode=view
It had changed a little, but the acrylic part is the same :-)
artexmg
Post by artexmg »
BTW, I added headsinks to the steppers, and saw that you did the same, great!. My question is: do you put some headsinks to anything else than the steppers drivers?
Thanks
GeraldO
Post by GeraldO »
So far, no, I haven't put any heatsinks on any other part of the machine. I'm currently testing out a hypothesis with the extruder stepper motor itself but I'll let you know if it pans out.
artexmg
Post by artexmg »
GeraldO wrote:So far, no, I haven't put any heatsinks on any other part of the machine. I'm currently testing out a hypothesis with the extruder stepper motor itself but I'll let you know if it pans out.
Good to know, let me know!
On the other hand, my Rostock Max V1, has a lot of heat seated on the Rambo due to multiple reasons:
1.- No Fan at all!
2.- Due to a switched piece during the build (I need to rebuild the entire rostock to fix it!), doesn't even have a "hole" in the back, so, all heat is seated in it.
3.- I usually I print outside the printing bed so I need a little more "grip power" on the stepper motors, which made me increase the current for the steppers,
4.- PLUS large prints +15 hours.
Still, I get very good prints out of it!
I am guessing that, once I reduce all the heat factor, the print quality should increase and get even better :-)
I will be able to compare V1 vs V2, and see what happens :-)
artexmg
Post by artexmg »
Ok, it is time to keep going!
The next step was the printing bed, I tried to put the cables the most organized way I could.
I liked the V3, with the new LED to indicate the Hot End is working, sweet.
Closeup
Closeup
Hot Bed ready to go!
artexmg
Post by artexmg »
Towers mounted with cables routed inside.
Then, with the cheapskates mounted (here a short vid on how they roll work (just like geneb's :-) ): http://youtu.be/L42-53poE8Q!
another angle
another angle
artexmg
Post by artexmg »
Top part in place
top part
top part
"aerial view"
this is all for now, but more coming soon, stay tuned! :-)
Return to “The Build Zone”
