[Solved] My first print failed - what's going on?
jeffhuber
Post by jeffhuber »
[img]http://i.imgur.com/WAAeX92.jpg[/img]
Is the hot end too close to the board?
or is the plastic not sticking well enough?
more elmers disappearing glue?
thanks for the help!
Rostock max v2 with e3d v6
Re: My first print failed - what's going on?
Your Hotend is too low, looks like it's pretty much scraping along the build plate, this will cause the espxtruder to eat the filament.
When you set your Z Height, everything needs to be up to temperature.
jeffhuber
Post by jeffhuber »
That solved it! Thanks Polygonhell!
