zeroing bed
Behold
zeroing bed
Post by Behold »
This may have been discussed but when I searched the issues didnt seem the same as what is happening with mine.
I have a Rostock Max ver 1.
My hot end became loose from the ceramic sheath and I replaced it with a new hot end.
The new hot end is a different length than the old one.
How do I adjust for the added length?
Behold
Re: zeroing bed
Post by Behold »
by the way if i start a print it slams into the glass... scary!
Normally use mattercontrol but have been trying to communicate through repetier to no avail
Re: zeroing bed
I believe it's covered in the manual, which is available for download.
Basically you need to adjust the X Y and Z max length settings in the EEPROM settings, I think the latest repetier has a quick way to do it from the LCD, but I don't use it.
Behold
Re: zeroing bed
Post by Behold »
yes, i found that part of it however i cannot connect with repetier. it says its connected but no manual controls or gcode commands respond
Re: zeroing bed
Check your com port in device manager.
If that doesn't work, see if you can connect with Arduino IDE and re-flash it.
Behold
Re: zeroing bed
Post by Behold »
The comport is correct since it is the same in mattercontrol and I am able to control and print from mattercontrol
Currently its COM3
Behold
Re: zeroing bed
Post by Behold »
Love your avatar!
Re: zeroing bed
If the com port is correct than the baud rate setting in Repetier Host must be incorrect.
The baud rate has to match what is in the Repetier Firmware.
Behold
Re: zeroing bed
Post by Behold »
adjusted the baud rate to 128000 and was able to connect
