Hi, just put together my Rostock Max V2 with rev 5 plate.
Running repetier host 1.0, calibrated the towers. Trying to print a ezfan shroud in pla (dont have ABS at hand) just for testing.
Im having some issues printing on the front side of the plate. The bowden stepper motor sounds like its skipping a few pushes of PLA and it doesnt lay down properly (see the image).
Its pretty new to me, so unfortunately i cant understand whats the problem.
Anybody know?
First print with the Rostock V2. Extrusion feed fail?
Re: First print with the Rostock V2. Extrusion feed fail?
what do you have your first layer height set to? looks like you Z is a little low on the one side. If you havent all ready, try setting your first layer to .3 MM
Lost pla castings? see me
Are you sure you did the COMPLETE calibration as indicated in the manual?
Hi, yes, completed the 4 script calibration "flowchart roundtrip" but i will do it all over to make sure.
Changed the first layer height from .35 to .3 now.
By the way, i want to print the fan shrouds with Taulman bridge, as i dont have ABS availiable.
What slic3r settings should i use? The same as the preset for glass or abs maybe?
going from .35 to .3 will only make it worse on that corner... TURN the end stop screw IN on that tower a 1/4 turn and try again, but keep first layer at .3
Having one of those moments of brain freeze...is it in or out to raise off the bed? havnt had to do it in quite some time...brain freeze..
Turn the screw in to raise.
Thanks, it helped!
End stop screw on the carriages...
Turn R ight R aise the nozzle
Turn L eft L ower the nozzle.
Only way I can remember it.
