Slic3r retraction settings issue
sabretoothnz
Post by sabretoothnz »
Can anybody tell me what slic3r setting is causing this to move back and forth when retracting?
10 sec video showing the issue:
https://www.youtube.com/watch?v=KbyHbmg ... oWGPojCJFw
Cheers.
DavidF
Re: Slic3r retraction settings issue
Post by DavidF »
sabretoothnz wrote:Can anybody tell me what slic3r setting is causing this to move back and forth when retracting?
Cheers.
thats the wipe setting....
Lost pla castings? see me
sabretoothnz
Right that's what I thought. But it is disabled. At the bottom in the gcode it says wipe = 0 . I'm using Slic3r 1.1.7 Stable
Cheers
; avoid_crossing_perimeters = 0
; bed_size = 280,280
; bed_temperature = 20
; bridge_acceleration = 0
; bridge_fan_speed = 100
; bridge_flow_ratio = 1
; brim_width = 0
; complete_objects = 1
; cooling = 1
; default_acceleration = 0
; disable_fan_first_layers = 1
; duplicate_distance = 6
; end_gcode = M104 S0 ; turn off temperature\nM140 S0 ;\nM106 P1 S0 ; Turn Off PLA fan\nM42 P6 S0 ; TURN OFF PEEK FAN\nG28\nM84 ; disable motors
; external_perimeters_first = 0
; extruder_clearance_height = 20
; extruder_clearance_radius = 20
; extruder_offset = 0x0
; extrusion_axis = E
; extrusion_multiplier = 1
; fan_always_on = 0
; fan_below_layer_time = 60
; filament_diameter = 1.75
; first_layer_acceleration = 0
; first_layer_bed_temperature = 20
; first_layer_extrusion_width = 250%
; first_layer_speed = 30%
; first_layer_temperature = 210
; g0 = 0
; gcode_arcs = 0
; gcode_comments = 0
; gcode_flavor = reprap
; infill_acceleration = 0
; infill_first = 0
; layer_gcode =
; max_fan_speed = 100
; min_fan_speed = 30
; min_print_speed = 5
; min_skirt_length = 0
; notes =
; nozzle_diameter = 0.5
; only_retract_when_crossing_perimeters = 1
; ooze_prevention = 0
; output_filename_format = [input_filename_base].gcode
; perimeter_acceleration = 0
; post_process =
; print_center = 3,-4
; resolution = 0
; retract_before_travel = 3
; retract_layer_change = 1
; retract_length = 5
; retract_length_toolchange = 15
; retract_lift = 0.2
; retract_restart_extra = 0
; retract_restart_extra_toolchange = 5
; retract_speed = 60
; skirt_distance = 5
; skirt_height = 1
; skirts = 2
; slowdown_below_layer_time = 15
; spiral_vase = 0
; standby_temperature_delta = -5
; start_gcode = G28 ; home all axes\nG1 Z300 F3000 ; lift nozzle\nM42 P6 S180; TURN ON PEEK FAN (FAN1)\n;M106 P1 S80; Turn on PLA fan
; temperature = 200
; threads = 2
; toolchange_gcode =
; travel_speed = 200
; use_firmware_retraction = 0
; use_relative_e_distances = 0
; vibration_limit = 0
; wipe = 0
; z_offset = 0
; dont_support_bridges = 1
; extrusion_width = 0
; first_layer_height = 0.35
; infill_only_where_needed = 1
; interface_shells = 0
; layer_height = 0.3
; raft_layers = 0
; seam_position = aligned
; support_material = 0
; support_material_angle = 0
; support_material_enforce_layers = 0
; support_material_extruder = 1
; support_material_extrusion_width = 0
; support_material_interface_extruder = 1
; support_material_interface_layers = 0
; support_material_interface_spacing = 0
; support_material_interface_speed = 100%
; support_material_pattern = rectilinear
; support_material_spacing = 2.5
; support_material_speed = 30
; support_material_threshold = 45
; bottom_solid_layers = 3
; bridge_speed = 30
; external_perimeter_speed = 80%
; extra_perimeters = 1
; fill_angle = 45
; fill_density = 20%
; fill_pattern = rectilinear
; gap_fill_speed = 30
; infill_every_layers = 1
; infill_extruder = 1
; infill_extrusion_width = 0
; infill_speed = 30
; overhangs = 1
; perimeter_extruder = 1
; perimeter_extrusion_width = 0
; perimeter_speed = 30
; perimeters = 3
; small_perimeter_speed = 30
; solid_fill_pattern = rectilinear
; solid_infill_below_area = 5
; solid_infill_every_layers = 0
; solid_infill_extrusion_width = 0
; solid_infill_speed = 30
; thin_walls = 1
; top_infill_extrusion_width = 0
; top_solid_infill_speed = 30
; top_solid_layers = 3
