Got one print out of my Droplit before I killed it....
guanu
SeeMeCNC Staff
Post by guanu »
Not sure what exactly happened, and not sure which took out what, but my second monitor output went out at the same time something popped on the projector I was using, and the inputs of the projector smoked.... but I did get ONE print out of my droplit before utterly destroying things....
now its painful to know I can be making awesome things, but cant because of projector death....
Anyways, I'm sure you don't care and want to see the print... so here is the one thing I got made
Guanu
Re: Got one print out of my Droplit before I killed it....
Wow, that's cool!
DavidF
Post by DavidF »
pretty costly failure... what resolution and which resin did you use for the print. It looks great.
Lost pla castings? see me
guanu
SeeMeCNC Staff
Post by guanu »
.1mm layers, makerjuice SF
Guanu
To be clear, you killed the projector. The DropLit itself is technically fine, right?
Generic Default
Post by Generic Default »
That print looks pretty nice, the resin printers will be better for complex shapes like that. You should test to see how low you can go in layer height.
Guess you'll have to wait. How exactly did you fry the projector?
Check out the Tri hotend!
