The machines...
Justin@Saturday
The machines...
Post by Justin@Saturday »
I posted this in the introductions already, but figured I'd share here as well. It seems like the right place.
Rostock Max v2 (the wiring is all outside the machine - so I can tinker with alternative boards, etc) and a uPrint SE Plus.
BONE
Re: The machines...
Post by BONE »
I should of done wiring on the outside also. I'd be fine with a separate conduit that has all the wires hidden inside. Running the wire inside the extrusion was such a pain in the a$$.
The BONE ZONE build thread.
Justin@Saturday
Re: The machines...
It'd be awesome if the guys at SeeMeCNC would modify the top and bottom wood plates to include a flat for a bit of Panduit (...or whoever...) conduit running top to bottom. Even if it was an optional sort of thing.
Re: The machines...
Check out the alternate cable routing method I show in the back of the v1 manual.
