Commands waiting?
craftymethod
Commands waiting?
Post by craftymethod »
Commands waiting lag?
Levelled the bed last night and today im turning it back on and faced with commands waiting? Im not sure how to clear! machine is unresponsive atm :S
craftymethod
Re: Commands waiting?
I tried restarting the computer... running the Ardurinor program and in windows 8 device menu ran the troubleshoot on the device before the Repitier program. I tabbed to manual control and it said no commands waiting.
Not sure but everything seems good!
craftymethod
I got everything up to temp and an object sliced but I tried to click the extrude to get some plastic out and nothing happened. Commands waiting again :(
craftymethod
I hit the emergency button and when it came back I was able to attempt my first print. I wonder what can cause commands waiting?
McSlappy
Post by McSlappy »
I'm guessing you solved this?
craftymethod
yeah mostly. Although Im sure it will stop responding again sometime hehe
McSlappy
Post by McSlappy »
I know that if I leave mine for a while it'll just stop responding and I have to reconnect it... But I don't think that's the same issue you had.
I see this occasionally, I think it's a firmware issue, I never saw it in the 0.8 firmware versions. I tend to see it if I extrude manually several times, though since I dropped the connection baud rate in an attempt to fix some comms errors I was seeing it seems to have gone away.
lightninjay
Post by lightninjay »
One thing you could try doing is lowering your BAUD rate in both your eeprom settings and your printer-host settings. Sometimes a computer just can't keep up and it'll throw errors.
