Working Repetier Host Firmware Config
All about the retired H-1.1 3D Printers
menza
Post by menza »
Can anyone post a working repetier firmware configuration.h and pins.h files?
Re: Working Repetier Host Firmware Config
We're just installing Repetier this weekend and should have something soon. What sorts of problems are you having?
What board are you running on?
menza
Post by menza »
I am using a RAMBO board. The problem I have is that the Z Axis more or less seizes up when I try to move it in either direction. I don't have this problem using Marlin, so I assume it is something in my configuration. I used the stock Repetier for Rambo files.
Return to “H-1.1 3D Printers”
