I also tried it at 60 speed but it was an epic fail. if it had worked - i would have gotten a quality part in 7 minutes!!! My nylon is pretty damp (lots of popping noises and steam) so I need to get a dry box setup.
Nylon is stringier because it has longer polymer chains. The molecules of nylon are ridiculously long, while ABS has more normal sized particles. So basically, nylon will try to stretch with the nozzle and will make a diagonals where the print is supposed to be a hole. ABS doesn't do it as much.
Which is why nylon is best for smaller nozzles and slower speeds and lower layers. If you dry the nylon in an oven, then keep it sealed in a container with desiccant the entire time you print, you will get a much better surface finish. Nylon is good for bearings because it has a really smooth surface finish and high abrasion resistance.
