How much Travelspeed you are using?
critical_limit
Post by critical_limit »
Hi everybody,
can you tell me what Travelspeed you are using with your Rostock Max / Orion printers?
I´m on 150mm/s, but due to oozing Nozzle want to go faster.
What is your experience on faster Travelspeeds?
cheers
Dirk
jeffhuber
Re: How much Travelspeed you are using?
Post by jeffhuber »
150 is standard, but I've used as fast as 200 with no problems.
Other people would know better than me - but it sounds like what you want is retraction, not faster travel speed to reduce stringyness...
Rostock max v2 with e3d v6
nitewatchman
Post by nitewatchman »
250mm/sec
Captain Starfish
Post by Captain Starfish »
600 - on a Max, though, and I'm pretty sure that the acceleration and/or firmware is limiting it to considerably less than that.
Tinyhead
Post by Tinyhead »
I've got mine set to 350 in Cura. As mentioned by others, I'm not sure if it's actually hitting that speed though...
