Installed CURA, now RH / SLic3r can't connect to Orion
TFMike
Post by TFMike »
It was recommended to me on here to try CURA in place of Slic3r to alleviate some of the buggy prints I was getting. I have been playing around with Cura for an hour or so fiddling with the setting until I found something I liked, (couldn't get the skirt AND brim to appear at the same time however) and when I imported the model gcode into Slic3r and went to connect to the Orion SD card it said that the printer could not be found and that COM4 didn't exist....oh lordy. I am in the process of uninstalling and reinstalling Repetier Host as I type this. Has anyone else run int oa similar problem?
teoman
Re: Installed CURA, now RH / SLic3r can't connect to Orion
Post by teoman »
Chexk the port in windows...
If you do not see the port there is nothing software can do.
Check the usb port (plug a usb flash drive etc to see if it works).
Check the printer side of the cable.
TFMike
Post by TFMike »
I uninstalled repetier and the rambo driver and now it works again, weird?!
