Holy 1's Build pics
Holy1
Holy 1's Build pics
Post by Holy1 »
Here are some pics of my build. It went together well with no problems except a faulty hobbed gear . see that post here http://forum.seemecnc.com/viewtopic.php?f=37&t=6373
I had a lot of fun building it learned quite a bit.
everything laid out, counted and ready to build
Cleaning up the excess wiring
first print in abs
first print in abs
Holy1
Re: Holy 1's Build pics
Post by Holy1 »
Some careful calibration and adding some PEI pays off. Check out the level of adhesion and how close I can get to the edge. This is ABS at 225 with the bed at 85.
2nd print - fan slid right in nice and snug
Tinyhead
Post by Tinyhead »
Very nice! Congrats on the build. Any separation on that large an ABS print?
critical_limit
Post by critical_limit »
Holy1 wrote:Some careful calibration and adding some PEI pays off. Check out the level of adhesion and how close I can get to the edge. This is ABS at 225 with the bed at 85.
Where did you get the PEI Plate? The only source I know is amazon mentioned here in another thread. But I´m waiting now for 2 month without getting it.
Can you post a source for the PEI Plates your using?
Thanx
Dirk
A very nice printer build!
What is the thickness of your PEI?
crocky
Post by crocky »
Holy1 wrote:Here are some pics of my build. It went together well with no problems.
Very nicely built machine and you attacked the power supply as well, got to be the way it's done. Wiring looks really neat too :)
Bob
Delta's are the way!
Holy1
Post by Holy1 »
Tinyhead wrote:Very nice! Congrats on the build. Any separation on that large an ABS print?
No separation.I had an enclosure around it (except for a quick pic).
Thanx
Dirk
I got the PEI last winter from amazon
Eaglezsoar wrote:A very nice printer build!
I got the .03 thickness in a 12x24 sheet. http://www.amazon.com/Polyetherimide-Of ... ywords=pei
Nylocke
Post by Nylocke »
You can get PEI sheet off McMaster for ~$30. Found a nice 12x12 sheet that's 1/16" I think
nitewatchman
Post by nitewatchman »
You might be happier with a thinner piece. PEI seems to be a poor heat conductor, within reason I think thinner is better. Mine is 1/32 and if I do this again I may try a little thinner.
nitewatchman
Return to “The Build Zone”
