Good little story here
3d Printed full size car
http://www.e-ci.com/baam-3d-car/?utm_ca ... i=14182600
						Print a CAR !!
Re: Print a CAR !!
looks like the part daddy has some compition LOL
Lost pla castings? see me
				Kevinvandeusen
- Generic Default
Re: Print a CAR !!
It's cool how it extrudes pellets like the huge SeeMeCNC delta. The surface finish looks pretty bad though. I was kind of expecting that a 1 million dollar machine would have more than one nozzle..... And it should be able to finish the exterior with milling after printing. A few extra axises wouldn't cost that much more. Sooner or later I'll have to make my own large printer. The materials would only cost a few thousand for something that size.
SeeMeCNC should print a functional surface to air missile on their huge delta printer for publicity. That cartesian one has a bigger XY build area, but the delta can do tall parts.
Check out the Tri hotend!
						Re: Print a CAR !!
Nooo! Seemecnc do not do that.
Then it will be reclassified as some other bullshit and we will not be able to import it.
						Re: Print a CAR !!
PartDaddy can probably do that right now, but the build would have to be in a vertical position to fit the build volume. Then it would lay down flat and you add the drivetrain and junk to make it go zoom.
				RAMTechRob
Re: Print a CAR !!
I would donate a golf cart if SeeMeCNC would like to be the second company to 3-D print a custom golf cart body.
