X Tower Motor Issue
- grimmindustries
X Tower Motor Issue
Hi Guys,
I was printing a calibration cube today and out of nowhere the X tower stopped working and my hotend is melting it's way through the cube. I checked the cheapskate and the belt. Eventually I took the motor out and tried running the home command and discovered that the motor at the bottom of the X tower doesn't have any torque now, if i put my finger against the gear the motor just stops turning but it sounds like it's still trying to turn inside.
Any ideas?
Thanks,
Ron
Any ideas?
Thanks,
Ron
dtgriscom
Re: X Tower Motor Issue
Some possibilities:grimmindustries wrote:Hi Guys,
- One of the four wires in the stepper cable is intermittent/broken
- One of the stepper coils has failed
- Your stepper drive has lost part of its driver circuitry
Dan
- grimmindustries
Thanks Dan, I'll check the resistance, I find that the motor spins loosely compared to the other motors when they are powered off.
Or maybe perhaps the set screws in the pulley came loose. This happens really easily, especially when you don't tighten them enough.
dtgriscom
Try this when the cables are all unplugged. And do make sure the set screw isn't loose; that's what thread-locker is for. Locktite makes it in stick form (looks like blue glue stick) which is really easy to use.grimmindustries wrote:Thanks Dan, I'll check the resistance, I find that the motor spins loosely compared to the other motors when they are powered off.
Dan
- grimmindustries
I did use thread lock when I built the printer, I'm going to go buy IPA so I can remove the set screws. It's definitely something inside the motor.
dtgriscom
I'm not sure there's anything you can really fix inside the motors, unless you find an obvious (and not buried) break in a wire. May be time to order a new one, or (if this is a new printer) talk to SeeMeCNC about a replacement.grimmindustries wrote:I did use thread lock when I built the printer, I'm going to go buy IPA so I can remove the set screws. It's definitely something inside the motor.
Dan
- grimmindustries
I ordered a new one and I did find that the rod coming out of the motor was so loose it fell out. I'll have to see if I can liquid weld it back in.
grimmindustries wrote:I ordered a new one and I did find that the rod coming out of the motor was so loose it fell out. I'll have to see if I can liquid weld it back in.
Green Loctite should do the trick for you.
- grimmindustries
Thanks I'll try it.
- grimmindustries
So the Loctite didn't last, any other ideas for re-attatching the spindle to the motor?
Replace the motor.
