look at your multimeter, it should have a symbol like this:
[img]
http://ww2.justanswer.com/uploads/theho ... y_test.jpg[/img]
or at least the lines like a speaker type symbol... that is continuity... set your meter to that (have your machine off) and to test, touch the ends of the probes together... your meter should make a tone... if so, you are on the right setting.. now put the 2 probes on each side of F3 fuse (you can see the metal on each side of the fuse, thats what you want to touch, one probe on each side at the same time) if you hear a tone, the fuse is good... if not, test F2... its a tougher to blow fuse, and you should get a tone... if you do on F2 and not F3, then F3 is a blown fuse... let me know if you can follow that
Guanu
