Medieval Broad Head - 0.05mm Layer
badgerman
Post by badgerman »
I read somewhere once that you wouldn't see much benefit from going below 0.1mm.. . . . . . I disagree!
a.ash
Re: Medieval Broad Head - 0.05mm Layer
Post by a.ash »
Looks good. What are you using to slice with, nozzle size? Is this PLA or ABS?
badgerman
Post by badgerman »
Slic3r to slice, the nozzle is the seemecnc 0.28mm and it is PLA.
I did have some interesting issues with the first and second prints - for example, I am printing it with 5 or 6 perimeters to be able to handle the super shallow angle of the broadhead and I have upped the top and bottom solid layers to the same amount. I did find with the first print that the temperature of the heated bed allowed the top face of the arrow to bubble in between the honeycomb infill pattern - no doubt due to the thin top layer.
a.ash
Post by a.ash »
Care to share your slic3r settings?
badgerman
Post by badgerman »
a.ash wrote:Care to share your slic3r settings?
Pour vous.
0.05 FINE PRINT.ini
(2.23 KiB) Downloaded 343 times
a.ash
Post by a.ash »
