Rambo LEDs
Rambo LEDs
Does anyone know where to find out the function of the various LEDs on the Rambo board?
Andy Wander
Re: Rambo LEDs
http://reprap.org/wiki/Rambo_v1.2
They're all on the schematic if you know enough to be able to read the schematic.
But to summarize, there's a power LED and a status LED by the reset button. Two LED's near the USB chip for transmit and receive on the USB port. And the rest indicate when their respective mosfet outputs are enabled.
Re: Rambo LEDs
Excellent PDF that should be downloaded by everyone using a Rambo board.Jimustanguitar wrote:http://reprapelectro.com/wp-content/upl ... Manual.pdf
There's a little bit of it here.
Great find!
Re: Rambo LEDs
Yeah, I already had that doc, but thanks for posting it.
What is the function of the status LED?
Andy Wander
RocketMagnet
Re: Rambo LEDs
I think the Status LED will flash when you press the reset button to let you know it's resetting/reset.
The flashing LED lets you know the Bootloader is loading... I think a bootloader is essentially like a computer BIOS for the board.. but I could be wrong?
Also I believe you'll be able to program it to perform whatever function you decide you want to assign to it and what you want it to indicate... useful debugging tool id guess?
From what I've seen from basic Arduino tutorials the "L" led is linked to a specific pin so you'll definitely know that pins State
as described here: http://arduino.cc/en/Main/ArduinoBoardUno
The Arduino stuff looks really interesting to me, the coding side looks simple enough and logically how it all works seems ok that I think
i'll buy some stuff to play with as I've limited base level electronics experience. Looks like fun and a good fit with 3D Printing
coupled with as far as I can tell the Rambo board is just a different flavour Arduino board?
Re: Rambo LEDs
It's the utility LED on digital pin 13 found on nearly every general purpose Arduino since day one. If you loaded the arduino blink program, that's the LED that would blink. That pin isn't connected to any rambo hardware besides the LED itself, but is broken out on the pwm header.awander wrote:Yeah, I already had that doc, but thanks for posting it.
I don't know if it's used as an indicator by any of the firmwares.
RocketMagnet
Re: Rambo LEDs
Ok looks like It's intended function is definitely for debugging... well that's what the official Arduino Project Book manual states on page 11.
Though I suppose as you can code it to light however you like to feedback whatever you want it to....
Re: Rambo LEDs
Well, that is on the bare Arduino. I suspect ot's telling me something on the RAMBO board.
I'll have a peek through the code.
Andy Wander
Re: Rambo LEDs
On the Arduino the bootloader is the program that runs first. It is the part of the program that enables you to program the arduino over the usb (virtual serial) port using the Arduino IDE (interactive development environment, fancy word for arduino softeare). It consumes about 2kb of your microcontrollers memory ( which should be 32kb). You can do without it BUT then you would need to purchase a separate programmer device to program the thing.
