Kinda looks like a MakerBot, only cooler
Features:
* See through front window made from plexi glass, 1/4" thick, completely removable, held in place by 4 magnetic catches
* Removable top - allows for easy access, I plan on adding a handle for ease of removal/installation and a 13"x17" 'window' so that I can look inwards from the top
* 120mm exhaust fan connected to a dryer vent pipe going out the window, I need to print a 120mm cowl, but until then duck-tape will do
* roomy work area allowing for on the fly adjustments of H-1 without removing
* H-1 completely removable if I need to take apart, modify or upgrade
* All power supplies/non-control hardware housed in separate compartment below H-1, I have a separate power supply for fans and CCFL lighting (soon)
I also plan on adding fan speed control, CCFL on/off and brightness control and others upgrades as I come up with them.
